Computers that generally don't include an integrated display, and are meant to be stationary.
2133 Questions View all
Networking, Lan,Network and sharing center
I have Three Desktop PC joint with D-Link ethernet hub, and two of this PC also connected through wifi modem for internet use. I use Cisco wifi reciver dongle for internet connection.
Problem is when i transfer file from one PC to onther pc .. file not going through lan cable but it use wifi dongle to send fil. So it become slow file transfer.
How can i configure networking ..?
Add a comment
1 Answer
Chosen Solution
Windows doesn't offer biasing with dual homing (your configuration here). So you can't have both connections active.
Another option here is to turn off the WiFi services so the desktop systems use the Ethernet connections only. Then connect the Ethernet hub to your internet router wired or via a WiFi Router to the Cable modem's WiFi AP. That way the connections are faster for both file sharing and to the internet.
The other option here is to have only on of the desktops connected to the both Ethernet & WiFi (multi-homed). Then you'll need to setup pass-though services making that desktop as a router for the other two systems.
Score 2
Add a comment
Add your answer
pankaj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 84
