Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
108 Questions View all
Is there a light on LCD Display?
is thee a light on LCD Display? Its balck screen working fine on external monitor. But on iMac is can see that the screen is just black but i can see windows of finder and other things which are open.
PS. I have it on mirror the display with external monitor
Add a comment
1 Answer
Chosen Solution
Yes, your LCD has a light source. And from what you are describing it is no longer working.
To make sure shine a flashlight at the front at a sharp angle you should see the faint outlines of the desktop icons. If that is the case you will need to either replace the inverter and/or CFL lamps.
Update
I would start by replacing the inverter. Here's the IFIXIT guide: iMac Intel 20" EMC 2133 and 2210 Inverter Replacement.
As for the part you'll need to give us the last four digits of your serial number so we can give you the correct part number.
Score 3
Comments:
Thanks Dan. That is exactly I was looking for and I can see the faint desktop icons and open windows. Inverter and/or CFL Lamps? How do I find the compatible for my version of iMac.
by
Hello Dan,
My serial # last four digit is 98TT Is this correct?
by
Inverter P/N: 922-8853
by
Here is the correct IFIXIT guide to follow: iMac Intel 20" EMC 2266 Inverter Replacement
by
Add a comment
Add your answer
sundeepshah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
