15" HP laptop with 2.60 GHz AMD Phenom II Dual-Core Mobile Processor.
11 Questions View all
Question Closed
No keys on my laptop keyboard work, can I fix it?
No keys will work on the keyboard. Ive tried uninstalling the keyboard and restarting my laptop. The touchpad works so i can still click on things and to use the internet i have to put on the on screen keyboard. would i have to buy and replace the keyboard or is it a hardware fault? The wifi button shows the light and it works. When the laptop is first switched on, the caps lock button lights up but after a minute it switches itself off.
Add a comment
1 Answer
Most Helpful Answer
hollyjackson612, sounds like a keyboard error. you do want to disassemble the laptop and make sure that the ribbon cables are properly seated. If all of that looks ok, replace the keyboard. Yes, there is a chance that it is the controller on the motherboard, but not very likely. Try the keyboard first. You can download the service manual from here. Hope this helps, good luck
Score 1
1 Comment:
Thank you so much! The manual helped a lot and it turns out the ribbon cable wasnt in properly and was sort of loose, i have no idea how though. Thanks again!!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 749
