Which threadlock to use for MacBook bottom case screws
I recently upgraded the ram in my MBP to do this i had to remove the back case, which i believe has broken the bond that the threadlock had when it was applied in the factory.
Now every 1-2 months i have to retighten all the screws as they keep becoming lose.
I plan to reapply the threadlock but had 2 questions :
- Which specific threadlock should i use, when i search amazon i can find lots but they seem to be for bolts and other 'larger' fixings, is there one specifically made for small electronics screws (i also guess i want one that is undoable ie. not permanent so i can open up the bottom case again if required)
- In applying the new threadlock will i need to clean the old threadlock off first with solvent ?
