Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1403 Questions View all
Why isn't my battery charging?
I just replaced the logic board on my friend's macbook. It was randomly freezing whenever picked up. The replacement fixed that issue however the battery no longer charges when I have the computer plugged in. I am getting a green light on the magsafe charger. I've tried reseting the SMC as well as using a different charger. I installed coconutBattery as I've seen suggested and here is my reading:
current charge: 0 mAh
Load cycle: 14
Battery Status: Good
Battery Temp: 25.9 C
Charging with: 0.0 watts
Battery State: discharging.
Any help is appreciated.
Have you replaced the battery recently?
My battery in my MacBook Core 2 Duo 13.3in. had the same problem. My battery was bulging about to either explode or leak!
When you ran Coconut Battery was the Mag-Safe adapter plugged into the machine? If so was it showing bright orange or green?
Add a comment
1 Answer
Chosen Solution
Download this little gem of an App: coconutBattery take a screenshot and paste it here for us to see.
I suspect either the MageSafe connector or the battery connector is worn or damaged. But before replacing things lets see what coconutBattery tells us.
I would replace the MagSafe connector first to see if it fixes things. Follow this IFIXIT guide: MacBook Core 2 Duo Magsafe Board Replacement. And here is the Battery connector IFIXIT guide: MacBook Core 2 Duo Battery Connector Replacement.
The last possibility is the comparator logic on the logic board is bad. But that would assume the replacement board was bad to start with.
MacBook Core 2 Duo Magsafe Board Image
Difficulty: Moderate30 minutes - 2 hours
Score 2
Add a comment
Add your answer
Marc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 121
