Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1392 Questions View all
How do I fix my screen that goes completely black?
So, I have had this model (Processor - 2.13 GHz Intel Core 2 Duo, Memory - 2 GB 800 MHz DDR2 SDRAM) for six years.
I'm running Mavericks and started noticing that when I adjust the screen past 30% brightness, it goes black. What I mean by this, is I can barely see the what's on the screen, without any backlight (if I hold it up to a light source I can see what the screen is displaying). I have been told that this model does not have an inverter, so I am wondering what I would be replacing. I have a brand new battery from Apple (which didn't help the issue at all).
One thing I noticed when unplugged (not charging) is if I start the screen at a 90 degree angle between the keyboard and the screen, I can keep my screen at 100% brightness. If I go to close my laptop, decreasing that angle, I can still keep my screen at 100% brightness. It is only when I go from decreasing that angle to opening it back up (from 20 degrees to 65 degrees), that the screen will go black. Once the angle between the screen and keyboard is greater than 90, I can go back and forth, without the screen going black.
Comments:
Can we double check your model here. Are you sure you have a MacBook Pro? Or do you have a MacBook Air? The Pro model had a 2.26 GHz CPU unlike the Air which had a 2.13 GHz CPU. If you give us the last four digits of your serial number we can check it out.
by
It's actually a Mid 2009 Macbook, not Macbook Pro.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Let double check your exact machine by giving us the last three figures of your serial number located in the battery compartment. If it is correct then you just need to replace the inverter, I'd replace the cables also. Here's how: MacBook Core 2 Duo Inverter Replacement
MacBook Core 2 Duo Inverter Cable Replacement
MacBook Core 2 Duo Inverter Image
Guide
Difficulty: Difficult2 horas
MacBook Core 2 Duo Inverter Cable Image
Guide
Difficulty: Difficult1 - 3 horas
Score 2
Add a comment
Sounds like it could be a faulty ribbon cable. Open up the machine and inspect cable and pin ends for damage.
Add a comment
Add your answer
Jay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 152
