Nintendo handheld device released February 2011, identified by model number CTR-001.
313 Questions View all
Nintendo 3DS Charge but won't turn on.
Hello,
Recently I got a 3ds - The small first version.
When I plugged it into the charger, I noticed the light turn on, but when I try to turn the device on - nothing!
The lights turn off when I press the power buttom and after a few secounds - turn on again without the decive coming to life.
theres no crack on the screen.
Thanks you.
Score 14
Comments:
I got the same problem yeah its stinks
by
I dont know what to do with it... how do u fix it
by
Same i couldnt find a way to fix it
by
I want to fix it plz help
by
i couldnt turn it off even O_O
by
Show 6 more comments
Add a comment
Chosen Solution
Could be a bad battery.. You can get them from Ebay
Score 4
Comments:
I took the battery out. The nintendo is supposed to turn on when plugged to the recharger, no?
by
Is the charge light coming on when you plug it in? You may want to check the charging port for damage or if it's loose..
by
Yeah, when I plug the charger the light turn on.
There's nothing when it's not plugged it.
Also I checked the connector, it seems alright.. nothing losses, no rust and it respond very quickly once I insert the recharger
by
jewhat when i try to turn my ds of it keeps making a noise and light turns of and when i try to turn it on again it keeps turning of
by
if the issue is the light is turning and and off, the what I did is I kept pushing the power button
by
Add a comment
Most Helpful Answer
Check the F2 fuse next to the battery contacts (for the 3ds it located underneath, other side of the logic/mother board). If the fuse is blown, then then system will charge for 10 sec and then stop.
Score 6
Add a comment
Take the sd card out and put it back in again
Score 5
Comments:
Sorry to say it but it doesn't work
by
Nevermind it works
by
THANKS! It actually seems to have worked, at least for my case! =D
by
Had the same problem. Ds would charge perfectly fine but couldn’t get it to actually turn on. Took the sd card out, blew In the system and put it back, came on the same way it used to. Thanks!
by
just made this account to thank you
i thought my 3ds had bricked for a moment
felt my blood pressure dropping
by
Add a comment
Hi these units get dropped from time to time, remove the back plate the battery and then the back casing. Look up towards the left trigger there is a small ribbon cable that can come loose if dropped. Lift up the small tab (carefully) remove and replace ribbon cable. Also there is a small square adapter in the center of the unit directly below the cartridge slot this is your wifi card once again gently pry up on it and it will come loose then reattach it. If these things don't work you more then likely have a tear in the ribbon cable that connects the screen to the motherboard. I have also on occasion seen this happen on a console that some one tried to hack and failed resulting in a hard brick of the motherboard, if that's the case you can try to find another mother board or sell it for parts.
Score 3
Comments:
Yo matthew barlup thank you so much
by
Add a comment
You need to charge it longer. If no response continues, try replacing the battery.
Score 1
Comments:
YESH DIS WORKED,all the other "replace the fuse or battery"thng didn't help at all CUZ MY FUSE IS LITTY AND IT LOVES MEH
by
Add a comment
Dang ok. welp gotta dismantle my 3ds and look for a ribbon cable and wifi card. jeebus.
Score 1
Comments:
%#*@ brother
by
why is dam n <--- blocked what the !&&*
by
okay even h ell is as well
by
The &&^&!!!!
by
okay wasn't surprised about that one
by
Add a comment
HaVe YoU tRiEd TuRnInG iT oN aNd OfF aGaIn?
Score 1
Comments:
yeeeeeeeeeeeeeeeee
by
Add a comment
This just happened to me!!
I recommend:
  1. Take SD card, dust that and blow into the SD slot then replace the card
  2. If you use the charging cradle (like I do!) put your DS in it tip it about a bit. Until the light comes on… I just have a loose connection
Edit: I have a 3Ds
Add a comment
Add your answer
ChubbyKai will be eternally grateful.
Past 24 Hours: 64
Past 7 Days: 610
Past 30 Days: 2,720
All Time: 89,333
