The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
221 Questions View all
Phone keeps switching on and off, stays off. What should I do?
My phone just switched off in the middle of a call and won't switch on now. When I try and switch it on, I just see the Google logo and then it turns off again. How do I switch it on again?
Score 7
1 Comment
Same issue here! To me it seems that when the battery goes below 80% it turns off. If I use an external battery to keep it up to 100% then it seems stable. I don't know if replacing the battery will help.
by
Add a comment
Most Helpful Answer
I'm having the same issue...from what I have read I gather that it is a faulty power button all together. Also my further reading leads me to believe that you either need to replace to motherboard or do some serious soldering in order to fix it.
Score 1
1 Comment:
I don't know if it's the same problem i'm having, but it's similar. In my case, it appears to be more of a display issue. The screen turns off at random, but at times it merely becomes touch-insensitive. And sometimes there's odd "static" on the display.
I assume it's a bad display connector; I'm looking into replacing the screen or having it replaced.
Hopefully I will *not* have to replace the motherboard.
Joshua, where have you been reading about this problem?
by
Add a comment
Replaced the battery and that fixed it. But be careful. The battery will catch fire if shorted.
Score 1
Add a comment
Take the fuckong battery cover off and literally flick the back of it right where the power button is a few times and press it at the same time on and off and you will see when it powers up then stop flicking it. Guaranteed to work 100%
Score 1
Add a comment
The battery holds less and less. Now it is down to half a day , worse when i use waze.
Do i have to buy a new battery?
Add a comment
I too had the same problem which I fixed myself.
It the problem with Power Button. Due to multiple ON/OFF or some moisture it is internally shorted, which means Power Button is always in ON state.
You need to de-solder it. and replace with working power button.
http://protyposis.net/blog/replacing-the...
Regards,
Gyan
Add a comment
Add your answer
Surabhi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,058
