The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
Screen stops working for days and then randomly works.
-Screen stops working in the middle of me using it
-when i try to reset it it will take me to the lock function to turn it off but because the screen doesn't work i can't slide it to turn it off.
-after letting it loose battery twice and charging it it started working for a bit and then stopped again.
is this worth fixing or should i just forget about it?
Score -1
Add a comment
1 Answer
Chosen Solution
Before I would give up on the phone I would open it up and check all the connectors inside and make sure they are properly connected. Use this guide: iPhone 1st Generation Display Assembly Replacement
Score 2
1 Comment:
It can be as simple as a loose connector.
by
Add a comment
Add your answer
Reyna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 524
