This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Questions View all
How can I put my Nintendo DS to its original colors?
My Nintendo Ds top screen its colors are almost in white when I turn on. What can I do too put it back to his original colors.
Score -1
Add a comment
1 Answer
Chosen Solution
If you can still make out the image, and it's not completely white, then it's likely not the screen or cable that is the problem. If you unscrew the battery cover you will see two small holes with what looks like Phillips screw heads. Turning these adjusts power to the screens, and improper power settings can make the screen appear too light or two dark. Adjust the screw (slowly!) until it displays properly.
Score 2
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,596
