Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
581 Questions View all
Why can't I see my texts I'm sending
I type in my text message and hit send and it disappears and does not show on the screen but the recipient gets it, can you tell me what's wrong?
Score 8
Comments:
I'm having the same problem. Also when this started I also lost my emotions
by
My phone just started doing the same thig today - I do not use my phone allot - i have hardly any apps- my phone was on the night stand, it says i have 5 new text messages and the nothing shows up. Also when i send a text message it just dispears and the privious text that was sent to me glitches or moves and then my disappears - I called my friend to confirm they recieved my text and they are but i cant see anything. ?
by
Me to just started doing it today.
by
I also have the same problem. My Samsung J2 (2016) sents SMS but there is no record where it has been sent. It keeps on sending as and when it desires. I am unable to find what message and to whom it was sent.
H.P.Agrawal
by
My phone went dead after a restart and when I was able to get it powered on I had the same problem.. I couldn't see my own messages going out but they were being received. I reset the date and time to my network (just turning on WiFi) and it fixed the text messaging problem. Hopefully mt fix will be as easy as all of yours, cheers.
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Most Helpful Answer
fix your time or your time zone that will take care of the problem
Score 9
Comments:
good job!!! worked for me. thank you
by
that's another thing my time zone changes automatically - i have had to change several different times.
by
I had to uncheck Automatic Time Zone and choose it manually. WORKED!! :) Much appreciated.
by
thanks! that worked!
by
It worked for me too! Each time I sent a text it would show the very last text not the one I'd typed but now it's working perfectly now I set the time manually. Thanks so much! xxx
by
Show 3 more comments
Add a comment
Switch from Samsung's message app to Google's Messages app.
Score 1
Add a comment
Try asking Samsung or your Provider. This is not a hardware-related question.
Add a comment
turn your phone off and on...
Add a comment
Try putting your texting back to original. Or default reset
Add a comment
If time is not set to automatic update date and time it will do this .Go into setting date and time and check auto update should fix it
Add a comment
Add your answer
burrichter237 will be eternally grateful.
Past 24 Hours: 12
Past 7 Days: 125
Past 30 Days: 432
All Time: 26,981
