The HTC Desire 816 features a 5.5-inch display with a 1280x720 resolution, 13 mp rear facing camera and HTC BoomSound.
65 Questions View all
Why doesn't my touch screen respond?
tounch screen of my mobile htc 816 does not work. I bought my mobile from 3 weeks and I do not know the problem come from
Please help me to find the prolem if it is hardware or software
Score 21
7 Comments
me also same problam -htc desire 816 i got before 3 weeks but noe touch screen not working - i am reset the phone also but no sucess. i have to go to seller now
by
My htc also same probelm my screen not working properly
by
my mobile also as like ur problem now what can i do plz suggest me
by
Wow I thought I was only having trouble my HTC desire is not working my screen is fine but no response it sounds more software but let's not leave The hardware out yet until we know sounds like HTC software
by
My HTC Desire 820ts touch is showing problems like if sometimes it does not respond . And also when I tap on one application , it goes to another . Please can you help me ?
by
Show 2 more comments
Add a comment
Most Helpful Answer
A soft or hard reset may fix this problem if it is software related.
To do a soft reset:
If the display is off, press the POWER button to turn it back on.
If you've set up a lock screen, you need to unlock it.
Press and hold the POWER button, and then tap Restart.
When asked to confirm, tap Restart.
If it does not respond when you touch the screen or press the buttons, you can still restart it. Press and hold the POWER and VOLUME UP buttons for at least 10 seconds. It should now restart.
Be sure to back up any data and files you want to keep before you do a factory reset.
To do a hard/factory reset:
Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Your phone should be set back to factory setting now.
If resetting doesn't get your touch screen responsive then you might have a faulty digitizer or a loose or broken digitizer ribbon cable or connector on the motherboard. The digitizer part of the screen is responsible for sensing touch. If you find fault in the cable you will need to replace the digitizer.
Score 12
9 Comments:
Superb and thanks dude...Please dont buy this mobile anyone this is very hectic and functionality is very bad.
by
thnku for the suggestion...
by
worst phone ever!
by
I've repaired the LCD + Digitizer with Frame a lot for many customers. Not a single one have come to me about this issue. If your system software is not up to date. I recommend to update it to the latest available update.
The digitizer connection shouldn't get loose. It's held around with grey adhesive tape making it pretty hard for it to come unplugged or loose by itself. Though the other flex cable connecting the digitizer cable to the logic board can become loose in some cases, It has foam behind the cable where it plugs into the logic board.
by
thanx a lot my friend it worked
by
Show 4 more comments
Add a comment
tap the screen with a hammer as hard as you can
Score 2
2 Comments:
my touch screen not working properly htc desire 526. very disappointed with this phone.
by
Lol don't listen to the guy above unless your fed up like me I may take his advice but before we smash our phones try updating software first
by
Add a comment
my HTC desire 816W has same problem.open automaticaly programs,and now left side of touchscreen is disabled.display is OK.but touch has problem.what is the solution?
Score 1
Add a comment
How can you go to setting and then recalibrate on something that is not responding to touch Raguraman?
Score 1
Add a comment
No it is not a hardware issue it's a software issue I also feel this issue after updating the latest software of HTC desire 816
Score 1
1 Comment:
what software version may solve the issue?
by
Add a comment
Solution
I also had this problem for quite a while. My phone does give me a headache because I can't always use it (I am getting a new samsung this June) but I have found a solution that works for me. What you have to do is create electricity for the screen. To do this, you create static electricity but rubbing your hand roughly against the screen until it feels very hot and it gets harder for your hand to slide across. This isn't permanent, and you might have to do it every time you pick up your phone, but it works.
Score 1
Add a comment
problem in hardwear in htc
Score 1
Add a comment
hello
my touch is not workng
i want to remove pattern how plz help me
Add a comment
Just switch of the phone and restart if it is not working go to setting and calibrate
1 Comment:
It worked for me . Great thanks
by
Add a comment
there should be problem in hardware n software to...first let me help with software issue if your touch is not responding swicth on the cell phone and only press switch on button for a long time and after pressing 1-2 minutes u r phone will be restart.....than it problem will be solved.....if it doesnt than open the cell phone and remove the touch pad there should be a moisture clean that and definetly it work..........**** if u like my answer best of luck
Add a comment
  1. Turn the phone off or remove battery and put it back. 2.Press the volume button to the lowest while you press the start button. Try a few times until you see a strange but simple menu. You can browse with the two buttons. 3. Go for recovery. It takes forever, but usually it works, and you´ll keep everything. In worst case; choose factory reset from the same menu. It´s not the screen.
Add a comment
And what happens when I press the hard reset buttons and it does not work
Add a comment
my phone htc desire 816 model display screen not working.
Add a comment
I know one %#*@ solution
If you recently changed your screen ,
Keep your screen cool (don't use it in hot surrounding) (like put it in front of air conditionar for few minutes and boom your screen works fine )..it becomes unresponsive when screen gets heated ….its an hardware issue not an touchscreen or software issue ..I have conformed it by myself
Add a comment
I have this problem as well but with the HTC U11. I already changed the screen and even with the new screen the touch is unresponsive. Does anyone know what may be the problem, or how I could fix this?
Add a comment
Add your answer
lubna ibrahim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 65,541
