Repair and disassembly guides for food cooling appliances including refrigerators, freezers and fridge-freezers.
273 Questions View all
Water not rising to icemaker?
I'm connecting a previously functioning icemaker that was without a water line for the last few years, but the fridge was still in use. The external line goes into the base of the fridge. A second line comes out of the base and goes up to the icemaker. I can see the water has risen about 2/3 of the way up the 2nd line to the icemaker, but has stopped. The icemaker is set "on" via arm position in the freezer. The external line is on. Not sure what is next. More info as I uncover it.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Solution:
The water line just needed time to come up to the ice maker. After a few hours and a shake, it eventually went up and filled the ice tray.
I also found a guide that may assist with this icemaker:
http://www.ehow.com/how_12021705_trouble...
Edits for the guide:
Re: Step One, the sensor arm going "up to the right" is clearly labeled as the "OFF" position on mine.
Re: Step Two, the *LARGE* nylon gear
Bonus: The adjustment screw behind the plastic face plate on the unit is apparently for water level, and is very fragile.
Score 1
Add a comment
Add your answer
scottbernardis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
