Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Install fully functional 16gb ram on my MacBook model 7,1?
From my understanding this model wasn't built to equip 16 gbs of ram. After some extensive research I recently found a few articles stating if the Mac book pro 13" Unibody Mid 2010 is identified as 7,1 in the system report it can be upgraded to a recognizable 16gb of ram.
One of the articles I'm referring to is one by OWC.
http://blog.macsales.com/16302-some-2010...
This company states only their ram is quality enough to succeed the 16 gb in a Mac book pro 13" Unibody Mid 2010 is identified as 7,1.
Is this true, or may I buy your 16 gb upgrade kit and successfully upgrade my mac.
Score -1
Add a comment
1 Answer
Most Helpful Answer
Wording is everything ;-}
A good salesman tries to imprint into your mind their product is better than someone else's. So the wording of OWC is somewhat ingenious here.
So heres the real poop:
First you do need to have the newest EFI firmware installed. Follow this Apple T/N: EFI and SMC firmware updates for Intel-based Macs.
Next you do need to get the correct memory modules: PC8500 DDR3 1066MHz 204 Pin and you do need to get two (2) 8 GB modules which also need to be a matched pair.
As to who's you get I would stick to one of the major memory houses and look at the pricing.
Even still I have found a few systems which should work don't. I suspect the clocking of the CPU and the Platform Controller Hub chip could be the factor. I've even taken out the modules of a working system and still find the system still won't handle 16 GB. Or, its possible the revision of the Platform Controller Hub chip was the factor. I never had time enough to make a deep study of it.
One last point the size of the chips and the number of chips (memory chips) on the memory module can also play a role in the cost. The older modules which have chunkier chips and have more chips will be cheaper. The newer slimmer chips and fewer chips (denser) will be more expensive.
Score 1
Add a comment
Add your answer
deathprince666 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,239
