The Blu Dash 5.0 Dual SIM D410 was released September 3 2013. Repairing this device is relatively complex and requires tools that have to be purchased.
82 Questions View all
phone is coming on and staying on "BLU" ,how to fix it?
my phone is coming on and the screen is staying on the word "BLU" and not coming on fully
Score 34
Comments:
How to solve this problem
by
Add a comment
Most Helpful Answer
i'm having the same problem.. but when factory reset and restart it.. the problem do not change :-(
Score 4
Comments:
i tried that method but it still didnt work..what other options do i have or what do you recommend?
by
Did u wipe the catch partition in the recovery? If not then try that. And if still that didnt help out. Then u may need to flash the phone. Look in here for answers on how to http://forum.xda-developers.com/android/...
by
i did it and phone not working
by
Add a comment
you have to boot into recovery and wipe data or factory reset..
remove the battery and wait for some seconds then insert the battery again
hold volume down and power button together until u see a recovery menu, then choose wipe data/factory reset us volume down/up to navigate .. then restart when done..
WARNING!personal data Like SMS/MMS/Contacts/Apps/call history .... will be gone for good if you need those then consider taking the phone a pro for backup..
Media such us pictures/videos/musics will not be affected
Score 1
Comments:
I tried that but the same thing is still happening!!!!!!
by
i tried that but the same thing is happening
by
Did your phone ever started working properly. Again. Guys??
by
its the same thing happening ugggggggggh
by
can you help me how to update the software
by
Add a comment
I had the Blu 4.0 star, and the brand itself is pretty bad :/ its a cheap brand, and I had that problem, and exchanged it, and the problem came up again :/ factory reset worked for a while, but it is a problem that will happened again and again. I would suggest a new phone.
Add a comment
yesnmk,l.;/""""""""nxdc nm b .n
Add a comment
use volume down/up to navigate and power button to select.
Add a comment
Did you get your phone fixed?? If so what did you do?? Im having the same issues with my Blu 7.0
Add a comment
Sim kit not in stole
Update (12/15/2015)
Add a comment
My phone only comes on to its logo. is a solution..
Add a comment
I had the same problem and i had to send it in. no reset would work. good luck
Add a comment
Add your answer
amanda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 2,863
