Why can't I get my MacBook to turn on or stay on?
I'm hoping that I can find the answer I'm looking for here because I cannot find anything anywhere about it.
I have a 2008 17" MacBook Pro that was actually given to me because the previous owner hit it hard enough to bend the frame where you would plug the Magsafe adapter into it.
I've done everything I can think of to fix it and still am stumped. I thought at first the obvious, that it damaged the left io board. However when I plug it in it will charge the battery. The battery keeps a full charge.
I was not able to get the thing to turn on at all until I removed the top case and shorted the power pads. After I was able to get it turn on I tried to look into everything to see if I could find any software problems. Nothing. I resettle scm, I removed the pram battery connection and plugged it back in. The strange thing is the when I reset the scm you have to restart the computer, which it did perfectly fine. The fans were on as soon as I shorted the pads and will not turn back on after I reset the scm.
For a very brief period of time I was able to turn the computer on and off (10 minutes) like normal, with the power button. Now we are back to square one and I can't even short the power pads again.
My question is why the heck is this happening? What could be causing this problem? What is it that I need to replace or look at? Finally, how the heck to test a typing from here?
2 Comments
Thank you for youre reply. It was never working. It was given to me because the previous owner could not get it to turn on. It did not turn on until I took the upper case off, unplugged the hard drive, pram battery, left io board, and airport card. I left everything unhooked for a couple hours. Once I hooked everything up minus the upper case I was able to use the power pads to turn it on. When I attach the charger to the computer it immediately dies. However it charges the battery perfectly. So the only way I'm able to get it turn on is with the power pads and battery, no charger plugged in. After I have it turned on if I shut it off like normal or by holding the power button (after I reattach the upper case obviously) I can use the power button to turn it back on. Of it dies any other way like if I try to attach the charger I have to unplug the battery, hard drive, io board and pram battery, let sit for what seems like atleast an hour then attempt to short the power pads again.
by Nick wilson
Ok well correction again. The hard drive is displaying on the screen. Just Very Very lightly. I have to hold a light up to the screen if I want to see anything.
by Nick wilson
