A comprehensive set of repair information regarding objects with specified tasks, usually for fixing or building.
336 Questions View all
Some one using TI EV2300 to program/hack a Battery back
TI EV2300 is a tool to program BQ series battery gauge.
I'm considering to get my A1185 out of "Permanent Failure" using EV2300.
Some one ever tried that or have some info/suggestion?
Thanks!
Add a comment
1 Answer
Chosen Solution
did you check the lipo cells first? are the fuses ok? - if a battery fails - it's most likely the problem of the cells and not the pcb inside the battery
so checking the voltage of every single cell and their fuses would be my first step - but that involves disassembling the battery (be careful and don't bent the cells)
Comments:
'cause i'll replace the cells and the g**d*** "self destructive" fuse. and i know what i'm doing.
just need some tool to reset BQ20Z80 status.
i don't know if this can be done by just programming SMBus...
by
Add a comment
Add your answer
Terrance will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 2,564
