2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
51 Questions View all
I dont know this part, is it a SMD Tantalum Capacitor?
I have and macboook pro i5.
3 of (22 1e20) are broken.
What component is this?
Where can i buy new one (ebay?)
I have searched the web but no clue.
Thank you
Comments:
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
FD, all three capacitors are 22UF 25V 20% Poly Tantalum Capacitors in a D2 case
Score 2
Comments:
Oke, thank you verry much.
are these oke?
http://www.ebay.nl/itm/50PCS-22uF-25V-6x...
by
D2 is a 7343 case with the 7.3 X 4.3 X 1.9mm dimension. So, those that you picked do not appear to fit sizewise. Something like a Panasonic 25TQC22MV should work for you. Also, remember that there is a reason those caps blew up. Make sure that you determine the cause of that. It most likely is not just a matter of replacing the components, try to determine what happened.This one http://www.ebay.nl/itm/PANASONIC-25TQC22... would work.
by
Add a comment
Add your answer
FD will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 295
