restart continouslly with samsung logo
i have samsung s4 , problem repeated restart , when show samsung logo restart again
what is the best solution without software , because i have names and much of data
Sir i tried butt nothing happen again restart
Sir I try it and nothing happen only the custom OS show up
If you can boot in recovery mode:
1. search for a rom that you can download and is compatible with your device.
2. You copy the rom on a external SD.
3. You boot into safe mode.
4. You click apply update from external storage.
If you can't boot in recovery mode waych this video:
Follow these steps below to troubleshoot or potentially fix this issue:
1. Boot up in safe mode:
- Press and hold the Power button.
- Once the Samsung Galaxy S4 logo appears on the screen (assuming the phone responds to Power key press), release the Power button.
- As soon as you release the Power button, press and hold the Volume Down key.
Continue holding the Volume Down key until the phone has completed the reboot process.
- If you can read ‘Safe Mode‘ at the bottom left corner of the screen, release the Volume Down key. Otherwise, repeat the process until you can boot the phone to Safe Mode.
2. Recovery mode:
- Press and hold the Volume Up, Home and Power buttons.
- Release the Power button when the phone vibrates but continue holding on to the Volume Up and Home buttons.
- When the Android System Recovery screen appears, release both the Home and Volume Up buttons.
- Using the Volume Down key, highlight ‘wipe cache partition.’
- Press the Power button to select the option.
- The phone will automatically restart once cache data are wiped out.
These are just two steps. If these do not work please let me know and i will further help you in your struggle.
Ryan (TechLegion)
when you try to log to recovery system the phone reboot after seconds
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,194
