Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Replaced iPhone 5c screen. The screen doesn't work if folded to close.
I replaced my iPhone 5c screen, and if I keep it open and have about 90degrees with the casing, the screen works fine when i press power button. But if I fold it to close the iPhone, the screen is black, and only shows backlit.
Any way I can fix this without getting another screen replacement part?
Thanks!
Score -1
Add a comment
Most Helpful Answer
Hi sLee , Unfortunately this sounds like the ribbon cable itself is damaged and from my knowledge it isnt repairable unless you have proper equipment which is probably more expensive and time consuming than just ordering a new screen. You probably already checked a million times but is the lcd connector clicked in tightly?
Score 1
Add a comment
Had it happen to me before was like said above the ribbon was damaged and when closed down wouldn't work a new screen is needed
Add a comment
Add your answer
sLee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 102
