I cant locate the fuel pump or starter main relay
I have a 99 accord that has been having problems with the antitheft system. and now the car wont turn over or nothing and I cant locate the fuel pump or starter main relay
The fuel Pump is located in the trunk. If you remove the cover sheeting of ply wood above your spare tire, you will see a wire going through a metal cover that has 3 screws. Take of the three screws you will need to hold the cover and unplug that. After that you're left with the fuel pump right there, if your checking it if it works then grab a 12 or 9 volt batter and where that plug is multiple electrical towers. The two in the center or closest to the center of the pump is a positive and negative lead to activate the pump. I hope that helps. For the Relay location is located either under the hood fuse box or on either side of the doors.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 254
