The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3448 Questions View all
Repair of screen went wrong, phone inop. Is it worth fixing?
My screen shattered. I bought a replacement but purchased an iPhone 5 repair kit rather than the 5s by mistake. My husband proceeded with the repair using instructions for the 5s (since my phone is a 5s). Soon after starting repair he realized he was trying to install the WRONG screen, but apparently had already damaged some little part inside by following the 5s instructions on the 5 screen. They are subtly different. We purchased correct screen, put it on, but touch screen is intermittent at best. Jumpy. Is this phone worth trying to fix? It's a 16g which I thought would be fine but 16 is not enough for my use. I'm just wondering if the phone is worth anything.
Comments:
It might be as simple as reshaping a contact to as complex as replacing a connector. Post an image of the part with your question.Adding images to an existing question
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Hi , This sounds like possible damage to the Digitizer connector on the board but would not be able to confirm unless i could see it. If you are able to post close up high quality pictures people could get a better idea as to whether the connector is damaged. If the connector looks ok then it is possible that the digitizer on your replacement screen is faulty.
Score 2
Add a comment
Add your answer
kimberly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
