Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Repair of screen went wrong, phone inop. Is it worth fixing?
My screen shattered. I bought a replacement but purchased an iPhone 5 repair kit rather than the 5s by mistake. My husband proceeded with the repair using instructions for the 5s (since my phone is a 5s). Soon after starting repair he realized he was trying to install the WRONG screen, but apparently had already damaged some little part inside by following the 5s instructions on the 5 screen. They are subtly different. We purchased correct screen, put it on, but touch screen is intermittent at best. Jumpy. Is this phone worth trying to fix? It's a 16g which I thought would be fine but 16 is not enough for my use. I'm just wondering if the phone is worth anything.
Score -1
1 Comment
It might be as simple as reshaping a contact to as complex as replacing a connector. Post an image of the part with your question.Adding images to an existing question
by
Add a comment
1 Answer
Chosen Solution
Hi , This sounds like possible damage to the Digitizer connector on the board but would not be able to confirm unless i could see it. If you are able to post close up high quality pictures people could get a better idea as to whether the connector is damaged. If the connector looks ok then it is possible that the digitizer on your replacement screen is faulty.
Score 2
Add a comment
Add your answer
kimberly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 108
