Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
601 Questions View all
Recommended hybrid 7200 rpm 500 gb HDD?
Dear All,
Current drive: Seagate Momentus 7200.4 500 GB 7200RPM SATA 16 MB Cache 2.5-Inch Bare Drive - ST9500420ASG http://tinyurl.com/m6kpgm7
I am considering upgrading to a 7200 rpm hybrid drive, as I am hoping that this will make my computer faster. I found the Seagate Momentus XT 500 gb 7200 rpm hybrid drive, but the reviews seem poor (see, e.g., http://tinyurl.com/od7fp7r). Is there another 7200 rpm ~500 gb hybrid hard drive that you would recommend?
Thank you!
Add a comment
1 Answer
Chosen Solution
#1. the price difference between the 1TB & 500 GIG is usually under $20.
#2. User reviews are like a*s holes, everyones got one.
#3. I've installed over two dozen of the Seagate SSHD drives with no problems and no failures.
#4. Replace the hard drive/IR cable as they are know to be faulty and destroy drives.
#5. put pads on the top level of the place where the cable goes over the top to prevent damage from the bottom cover hitting the cable.
Score 2
Comments:
Thank you so much for your comments. A few questions:
#1 As far as I can tell, many of the 1 TB hybrid drives are actually 5400 rpm and not 7200 rpm (see, e.g., http://tinyurl.com/ofcqq69). Would a hybrid 5400 rpm be faster than my current non-hybrid 7200 rpm drive?
#3 Do you mean that you have installed dozens of the Momentus XT drives with no problems and no failures? Thank you!!!
by
The 8GB of SSD Ram on the 1 TB is where your speed comes from. I believe the 500 drive only has half of that. Anyway the most used programs and the operating system will end up on the SSD after a couple days of use. Thus negating the need for a higher RPM drive. I used to use the XT drives before the SSHD drives came out.
by
Thank you so much for the clarification and for your rapid reply!
by
Add a comment
Add your answer
misha680 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 95
