How can I replace a broken headphone jack on my iPod?
The headphone jack on my iPod is not working. Only the left side works. How can i fix or replace the jack?
it could be a lint inside the headphone jack or in the worst case - a loose/broken connection of the headphone jack.
the first thing i would try is to look into the headphone jack - and signs of "dirt" inside ?? - maybe you should blow into it (some people use canned air for that)
if nothing helps - it's possible that the flex cable is broken (they break pretty fast)
you can replace the part - but soldering is necessary!!
use the logic board guide - you can see the part in step 9.
but soldering some wires to it is also possible....
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,606
