2.26 or 2.4 GHz / White plastic unibody enclosure
634 Questions View all
How do I reconnect speaker wires to logic board?
Unable to find original holes on logic board. What is the best way to reconnect speaker wire to logic board?
Update
Yes. I believe you are correct and that connector was removed from the Logic Board.
Is there any way to correct this?
Score 1
Comments:
Pictures could help here so we can see the damage
by
Add a comment
1 Answer
Chosen Solution
Sounds like you pulled off the connector on the logic board. Can you take a couple of good pictures so we can see what happened. We need the cable end and the location the speaker cable would connect on the logic board. Review this picture as reference: Speaker connection.
Score 2
Comments:
I have a picture but don't see an Attach File button.
by
It's a bit tricky, here's the steps: Technique: Adding images to an existing question
by
Add a comment
Add your answer
w7744 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 69
