Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3256 Questions View all
iPhone 4 error(0xE800002D) wont activate on itunes.
i just update my iPhone 4 firmware to 7.1.2
before updating, my iPhone wifi is not working. i.e greyed out wifi.
now, i cant activate my iphone on connecting to itunes.
i got an error message on itunes "The iphone could not be activated because an unknown error occurred
(0xE800002D). Please try again later.
Score 26
Add a comment
Most Helpful Answer
you have to download the earlier firmware. I don't recall which one I think it was 6.1.3 but I don't know for sure but I do know you can download the firmware and then when u go to iTunes you hold down shift key and click on update and itll open the dialog window and you can then choose the firmware that you downloaded in order to go downgrade the firmware. for step by step directions google how to downgrade to an older firmware. hope this helps! that's what im doing right now lol
Score 1
Add a comment
Hello if wifi is grey out it will cause this issue the phone will be useless until Apple stop signing the signatures on that firware
You can downgrade but I think you need shsh blobs saved
Add a comment
เชื่อม itunes แล้วขึ้นว่า error800002D แก้ยังไง พึ่งล้างเครื่องไปแล้วเราก็ลบ appleid ในเครื่องไปแล้วอะ wifi ก็ใช้ไม่ได้
Add a comment
/iPhone+4+error(0xE800002D)+wont+activate+on+itunes
Comments:
by
Add a comment
Fout melding 0xE800002D op mijn pc .Kan foto's van mijn I Phone niet op PC zetten! Hoe kan ik dit oplossen?
Add a comment
I visit https://applenerds.com/2017/10/03/error-... and I got some possible solution
Add a comment
how to opin my iphone 4s is disabled
Add a comment
Add your answer
Dil Tako will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 91
All Time: 21,464
