Part Number: DD11210
The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
This is most likely due to a broken impeller, and the impeller assembly will need to be replaced. It could also be due to air locked in the pump housing, which is most likely due to the pump not be fully submersed.
