Michael, start with the easy stuff:"
No Video, No Boot Chime
The computer will turn on, but there is no boot chime and no video on the display. The faint sound of the fans, hard drive, and optical drive may also be heard.
1. Make sure all software updates have been applied to the computer. Refer to KBase article 303903, Intel-based iMac: Installing available updates , and to Apple Downloads for updates for the iMac (Mid 2007) model of computers.
2. Follow instructions in the “General Information” chapter to reset the SMC. Does the computer display video after successfully resetting the SMC?
Yes: Problem solved.
No: Continue to next step.
3. Verify that only supported SDRAM memory has been installed and that it has been installed correctly. Unsupported and/or defective memory can prevent the computer from booting. It may be necessary to install known good memory for testing purposes and replace any unsupported or defective SO-DIMM’s identified during this process. Does the computer display video after verifying and/or replacing the memory with known good memory?
Yes: Problem solved. Verify full system functionality before return the system to the customer.
No: Replace the logic board.
before replacing the logic board, check this as well:"
No Video, Boot Chime Heard
The computer will turn on, the boot chime can be heard and activity from the fan or drive can be heard, but the display has no picture or color.
1. Make sure all software updates have been applied to the computer. Refer to KBase article 303903, Intel-based iMac: Installing available updates , and to Apple Downloads for all available updates for the iMac (Mid 2007) model of computers.
2. Check if the computer is sleeping. Press the space bar to wake the computer from sleep mode. Did the computer wake from sleep?
Yes: Put the computer to sleep from the Apple menu and wake the computer again to test. Check Energy Saver setting to see when the computer has been designated to sleep.
3. Reset your computer’s PRAM (Parameter RAM):
Shut down the computer.--
Locate the following keys on the keyboard: Command, Option, P, and R. --
Turn on the computer.--
Press and hold the Command-Option-P-R keys simultaneously. You must press this key --combination before the gray screen appears.
Hold the keys down until the computer restarts and you hear the startup sound for the --second time.
Release the keys.--
4. Does the computer display video after successfully resetting the computer’s PRAM?
Yes: Restart the computer from the Apple menu and make sure the computer is now working correctly.
5. Make sure the machine is powered off, and remove the access door and front bezel to access the diagnostic LEDs. Plug in and start up the computer to observe the diagnostic LEDs. At this point in the Power On process, you should hear a boot chime, and LED #1 and #2 are On. Is LED #3 On or Off?
LED # 3 is On: The video card and logic board are communicating properly. Go to the next step.
LED # 3 is Off: The video card and logic board are not communicating. Replace the video card. If the issue persists, replace the main logic board.
6. LED #4 should be On when the video card and LCD display have communicated properly to produce a video image. Is LED #4 On or Off?
LED #4 is On: The video card and LCD display have communicated to produce video. In this case, there is a problem with the backlights in the panel or the inverter. Verify the inverter cable is fully inserted into the cable connector on the inverter and check that the wires have not been pinched. Replace the inverter cable first and then the LCD panel if the problem persists.
LED # 4 is LED # 4 is Off: The video card and logic board are unable to communicate to generate video. Replace the video card and install the iMac Graphics Firmware Update.. If the issue persists, replace the LCD display.
For reference: Technique: iMac Intel 24" EMC 2134 and 2211 Diagnostic LED's
by Dan
Update :
Just take out graphic card, interesting is 3out 4 LED's ON ?
by Michael
@michael: 'Only the first three of four LED lights up' Don't think its the graphics card if it was the 3rd LED wouldn't light (and maybe even the 4th LED).
by Dan
it must be logic board, please take a look at the picture three out four led's on.
Without graphic Card
https://db.tt/tWZAvlmr
Is anything else that I can do with this board, how to diagnose what is wrong ?
by Michael
Sadly, there is very little you can do to fix a logic board without having the needed tools and a bunch of replacement components to swap out. I gave up trying to get that deep, as my eyesight isn't what is use to be. for about $200 US you should be able to find a used logic board to replace yours.
by Dan
Show 1 more comment
