The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 Questions View all
showed three rings again nothing else works what do I do?
I installed the rrod fix kit to the detail and was Starting to place it together and I plugged the power cable in and the vid/audio cable in and pressed the power button it turned on the fans started and immediately kicked off and showed three rings again nothin else works what do I do ?
Score -1
Add a comment
1 Answer
Most Helpful Answer
jmarbs95marble, the kit is strictly providing additional pressure on the GPU/CPU to try to close cracks in the solder joints ( as well as reconnecting the bumbs, long story). Combining this with a reflow with a heat gun may just complete a good repair. Check on here step 49 will explain it. Check on here for the reflow guide. Also "remember that all that this kit is trying to accomplish, is to close cracked solder joints. Most of the time the extra few pounds of torque provided by the kit, will close those cracked joints. It is not a permanent fix, nor is it a sure thing either. It all depends on the individual logic board and the damage to the solder joints as well as the chip itself I strongly suggest a reflow with this kit. The chances to be successful is greater with a combination of RROD kit and a reflow. Of course, a permanent fix would be a total reball. for a reball to be done, you will need the stencil, a rework machine as well as the proper reball temperature template. If you do not have those tools, you can not do a reball. This will give you a pretty good idea on how to do it. As I mention in here, even a reflow may not be a sure thing either. It depends how you did it, how much experience you have to reflow it, and how bad the GPU solder has cracked. I suggest a reball to get it permanently fixed. Hope this helps, good luck
Xbox 360 Red Ring of Death Fix Kit Image
Guide
Difficulty:
Difficult
45 minutes - 1 hour
Xbox 360 Image
Guide
Reflowing Xbox 360 Motherboard
Difficulty:
Difficult
1 - 3 hours
Score 1
Add a comment
Add your answer
jmarbs95marble will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 37
