Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
258 Questions View all
connects to itunes ,screen is blank
i have a mini 2 that was working fine until it faded and didn't responded i tried resetting the device but it no longer function i opened it and remove the LCD and the iPad starts connecting to iTunes but the screen stays blank even with replacement.
Comments:
Lit screen and no image (back light seems ON if you look at the back of the screen); has image but no back light (you can see something on the screen, but it is acting as if brightness is stuck on minimum); or no image nor light?
by
no image or light
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If resetting and replacing with *known good* screen does not restore an image, then your iPad could be suffering from a fault at the level of the logic board.
However, image circuit and back light circuit rarely fail together. So are you sure that there are neither an image (very dark) nor back light (edges of the LCD when seen from inside are lit, but no image)?
Comments:
i checked no image or light device will sync with iTunes and restore without any problems is there a place that can fix it?
by
Where are you located?
by
Pennsylvania
by
You can look up jessabethany's profile on this forum, where you'll find some details and contact info. You can contact her about this issue, she'll guide you through the possibilities and cost. You can mail the iPad to her. I'm saying this because I'd use her services if I was there and needed this kind of support.
by
Awesome Thanks for the help!
by
Add a comment
Add your answer
acelot29 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 443
