The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3504 Questions View all
logic board grounding brackets?
will not haveing the grounding bracket installed prevent charging the phone? or any other issues?? basically what's it important for.
Add a comment
Chosen Solution
I just got one in that had that bracket missing. The phone would only boot half way thru with out it. It helps hold the connectors in tight. Once I replaced it the phone worked fine. See if this part in step 11 & 12 is what you are talking about: iPhone 5s Logic Board Replacement
Score 2
Add a comment
You have to specify which one.
Some of those brackets are not just for grounding, they actually conduct RF signals. If those brackets are missing, you will lose reception.
Score 1
Add a comment
Should be fine, If you have any doubt you could insulate with some electrical tape to make sure there is no short between the motherboard/housing/underside of screen.
Comments:
i think you misunderstand me, there is a bracket between the motherboard and housing, connecting/grounding it, this part is missing on my phone and i want to know if thats why it won't charge? because the battery is fine and the flex cable is fine.
by
Add a comment
Add your answer
jai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 48
All Time: 659
