Complete disassembly and installation guides for most recent Mac laptops and consumer desktops.
29197 Questions View all
Why does my mac no longer see the external mic input?
I have a 2003 macG4. I am attempting to use garageband with an external mic port input with my korg keyboard. Coming out of the left channel korg output (mono) to the mac line-in. I am using a standard 1/4" phono cable (male-to-male), then into a 1/4" to mini adator to go into the mac.
My mac does not "see" the line-in port.
Did I "blow" the port with this set-up?
Should I have used the headphone out from the korg instead? I tried setting the references (both mac & garage band) and it still does not see the line in. It does however, see the usb...so, what the..?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Adaptors
are notorious weak spots in cabling. Try a direct patch cord.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Score 1
Comments:
+ agreed
by
Add a comment
Hey thanks. It's me, the guy with the problem. So, you're saying the adaptor from 1/4" phone to mini into my line/mic in on the side of my '03 G4 may be suspect? What would a direct line in be then? A device with a straight mini in? Ok, I will try that. Would you suggest I also try a new adaptor? And nobody answered whether or not I could have "blown" the on-deck input with the source I was (possibly) sending (Korg left channel (mono) out, as opposed to the Korg headphone out - (lower wattage, I think).
Comments:
Well, if you're using a 2003 PowerMac G4, they do have a history of problems in the audio system. Though there's a low chance that you actually blew the connection, if you did, and you have a PowerMac (Not an iMac, Mac Mini, iBook, or PowerBook)G4, you can put in a PCI audio card, that is mac compatible to use for sound I/O. M-Audio has a few different mac-compatible PCI cards on there website, if it is required.
by
Please update your original question only Answers go here. Yes a straight wired (soldered) patch cord - no adaptors. I agree with Chris on the likely hood of blowing the port, and what's a good workaround.
by
Add a comment
My mac does not reconize my external mike on Skype. I can plug my ipod in to it with a male to male patch cord, and it shows response on the output scale, but the person on the other end of skype cant hear it. Help.
Rick
Add a comment
Add your answer
chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 942
