Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1392 Questions View all
Battery will not charge any more?
After a hard drive failure and a reinstall of Snow Leopard on the new hard drive, the computer will not charge.
So I replaced he MagSafe board per the directions on this website.
I only have a faint green light on the MagSafe charger end and a message under the battery icon that says "Battery Failure, replace battery immediately."
I replace the battery and now it says "battery not charging."
Coconut battery indicates 127 cycles and zero charge and 95% capacity available.
What could be wrong?
Comments:
Thanks Majesty, I should add that I have reset the PMU and the PRAM but no help.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I would reset the PMU and PRAM, these resets sometimes cure some some odd behavior like this.
Score 2
Add a comment
Too late for you but maybe for someone else - replace the Battery Connector. I've seen a lot of these fail since this question was asked.
Score 1
Add a comment
Add your answer
040304 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,237
