The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3315 Questions View all
Volume flex not working after repair?
Fixing for a friend. Usually a simple repair. He tore the flex trying to replace the screen. I put a new one in, tested, no tears, hold switch and power button work, but no volume. clicks but no response. help? thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Disconnect the power-mute-volume cable, clean the connector with a cotton swab dipped in 90%+ isopropyl alcohol, re-seat gently and firmly.
Do the same for charging dock cable.
No change? Test the buttons while charging dock cable is disconnected from the board.
If still no change, you probably installed defective cable. Happens a lot.
Score 1
Comments:
Friend or you could've also knocked off something during initial repair. Check around the P-M-V connector on the board for missing/broken/damaged components.
by
Add a comment
Add your answer
Austin Harris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
