The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3303 Questions View all
Low signal and microphone after dropped to water
Hi,
I have an Iphone 5s. I accidentally dropped it in water in my dream( don't ask how) and it stayed in water for at least a few hours(maximum 8). Fortunately it was in an Otterbox Defender, which saved it from an immediate death. Everything works perfect except from two things: there is low signal( 0-2 in my town(in bigger cities it raises to maximum) and the mic during calls is not working( with a microphone connected as well). 2 men tried to repair it, but non of them succeeded. The first one was an idiot but the second one is a respected and good technician. I researched a lot, and I found that replacing the "lightning connector& headphone assembly" maybe helps. I asked the second technician whether he had replaced this part or not and he said yes and he said only a logic board replacement could help. I don't believe him. The logic board is too far from the speaker/microphone where it got wet. And, there is two things not working on the "lightning connector& headphone assembly". Do you guys think it worth buying one and replacing the old one? I
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
In my opinion, I would replace the lightning connector and headphone assembly. The logic board does not have anything to do with the problem.
Here is the link to the repair guide - iPhone 5s Lightning Connector Replacement
It should only take you 25-45 minutes to fix and about $30.
Let me know if this helps.
Add a comment
Thank you very much!
Knowing this, I will give it a try. I am from Hungary, where IPhone parts are really expensive, but I found a used and working lightning connector and microphone assembly for 4000 Huf( <20$). It's worth to try I think. I once replaced my battery with no problem, and I have a few tools as well so I can do it. The spare part maybe arrives on Wednesday so I will reply soon.
Keep your fingers crossed for me!
Add a comment
Add your answer
robotboy98 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
