Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7
265 Questions View all
which ram to choose? and maximum ram I can install?
Hi,
I need to know the specifications of the ram I need to buy and which is the maximum ram my iMac can have. At the moment it is running on a 4Gb ram.
Thank you!!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
From EveryMac: "By default, 4 GB of RAM is installed as two 2 GB SO-DIMM modules. Two slots free.
*Officially, this model supports a maximum of 16 GB of memory. However, third-parties have discovered that it actually will support 32 GB of memory using four 8 GB modules."
The memory modules are: 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin)
Don't forget to make sure your firmware is up to date! Follow this Apple TN: EFI and SMC firmware updates for Intel-based Macs.
Score 1
Add a comment
Add your answer
Sergio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 65
