The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
235 Questions View all
Broken 2013 logic board, upgrade to 2014?
My logic board on my MacBook Air 13" mid 2013 is damaged from coca cola spill :/
Can I change the 2013 logic board to 2014?
Comments:
Please give us the last four figures of your serial number (located on the back in very fine print), so we know your exact machine.
by
Or maybe I can downgrade to 2012? Cheaper...
by
Will mid2013 1,4ghz fit into this? I have mid2013 1,3ghz.
by
Cleaned all parts.
Well, now it starts... but stops again... will do the cleaning again.
https://www.youtube.com/watch?v=_hSYSUqT...
by
I can't speak for this specific Air. Some of the older ones had issues with using a different revision of the same LCD with the motherboard.
by
Show 3 more comments
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Here's a listing of systems within this series: MacBookAir6,2.
As you can see there is a few Early '14 that you could swap out the logic board with. These logic boards are not cheap! You may end up being happier just buying a new system.
You still could have issues within the keyboard and trackpad from the spill. So think this through carefully.
Score 2
Add a comment
It works! Washed it with isopropanol :) Everything works!
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 226
