Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
I changed the inverter board but the screen is still not working!
My screen suddenly turned very dark.
The computer is on but the brightness is zero.
Right now, I can only set the brightness to 1,
it's the only way the computer stays long enough for me to work on it.
But it's annoying that I cannot see in full brightness and keeps turning dark again suddenly.
I thought the inverter board was broken, so I bought a new one and replaced it but it's still the same.
I turned off the automatic display light setting, and have tried
resetting everything but it didn't help either.
Should I change the inverter cable? or the lcd screen? or both?:(
I'm a college student, so I can't afford a new computer..:(
Please, help!
Add a comment
Chosen Solution
Cable first
it's cheaper, then the screen if that's not the problem.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Comments:
I'm going to try connecting my laptop to the external monitor, if it works fine, then can I be sure that the cable is broken? not the lcd screen?
by
Add a comment
Most Helpful Answer
Was the MacBook dropped before the lightning problem started ? If so the backlight (CCF lamp) or the logic board could also be the culprit.
Score 1
Comments:
No, It started when I left my computer on to get some lunch..I ordered the inverter board from some web site It's older than my original inverter board. I unplugged the black cable on the left side to test it, the computer lights up but when I put it to full brigtness, it gets dark again. Do you think I bought a broken one? Should I get a refund?
by
I would try the external monitor before doing anything else.If it works there it could be the cable or LCD-if not you probably have a logic board problem Ralph +
by
I just connected to TV, it works fine. I don't think it's a logic board problem.(thank god!! :) So I should try the cable then.if not the lcd screen...
thank you all! :)
by
Add a comment
Add your answer
Yuri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,446
