The Power Macintosh G4 is series of personal desktop computers released by Apple in 1999, and sold through 2004. This page is for the M5183 designation.
42 Questions View all
9.2 OS, no admin. password, how can I get in?
Had OSX 10.1, inadvertantly overrode with 9.2. Is it possible to delete admin. password requirement? Can I buy a used larger hard drive with later OSX and put it into this unit? Thanks
Bill Wells
Comments:
What are you putting in into?
by
To get a good answer you really need to write a good question. Your question is like swiss cheese.
by
Add a comment
Chosen Solution
If I knew which G4 you have what speed and how much RAM I could give you a much more specific answer. But here's where you can get all manner of older system software: http://fastmac.com/osx.php
Score 3
Comments:
Thanks! This is description of my G4: Family No. 5183, SN:XB00637ZHXF, Ethernet ID: 0030654D12EE, 450MHz, 1M Cache, 128MB SDRAMM, 20GB, HD/DVD-ROM, Zip 56K, Mode M KB. Does this help you to help me? I will try the fastmac address that you sent. Thanks!
by
You can install up to OSX 10.4 on this machine. With the addition of another 128 MEG RAM stick. Here's the system requirements: http://support.apple.com/kb/ht1514
You can then also add the System 9 OS to be able to run in "Classic Mode".
by
Your machine has four RAM slots. It will takes up to 2 GB of PC 100 SDRAM DIMM's. Here's some available sticks: http://www.ramdirect.com/vcom/index.php?...
by
You can also either add or exchange the Hard drive. A second drive can be placed on top of the first one. The cable support is already there. Just make sure the new drive is a ATA or IDE and under 128 MB. You will need to set the jumpers on the drives (one to Master and one to Slave).
by
Add a comment
Do you have the original installation CD's that came with the machine? If not, a quick Google search will yield you results.
Add a comment
Thanks for your reply. No, I don't have the original installation CD's as I purchased it used and seller did not have them. What info should I input to Google to try to find installation CD's?
Thanks again!
Add a comment
Add your answer
Bill Wells will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,709
