The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3315 Questions View all
iPhone 5s won't turn on after housing change
Hi have an iPhone 5s was in full working order prior to changing the entire housing, screen and home button as well as the lightening connector/headphone jack cable.
Now the phone won't turn on!?! I've tried pressing the screen cables and battery cable but still no luck.
I had a lot of diffiiculty removing the battery and had mid-shaped it but there was no visible leaks or holes so I flattened it gently and put it back into the phone..
So can anyone solve this mystery?? Thanks in advance :)
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Do you have a multimeter to check the battery? Did you remove the battery by peeling the gum glue underneath or just prying it off? You may have damaged the battery when prying it. There's an easy to remove the battery by using the pull tab at the bottom of the adhesive.
Check to see if you knocked/damaged any of the diodes or chips.
Score 2
Comments:
Prying from the right
by
Add a comment
Add your answer
Ryan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 295
