Dies immediately on startup
Hi,
When I start up my MacBook the light in the front turns on, I can hear the CD start but then it dies. Since I have another identical one I've tried replacing the battery, memory, hard drive and even unplugged the CD but still no luck, the light in front comes on and then it power off almost instantly.
When I plug in the power adapter it will lit up so I'm guessing it's not the left I/O board.
So what to you think? Is the motherboard gone? Can you recommend anything that I could try out?
Thanks in advance,
Indridi
7 Comments
Let's start off by properly identifying your MBP. what are the last four digits of your computers serial number? that will help us to find the proper computer and the proper hardware used.
by oldturkey03
Thanks for you reply,
The last four digits of the serial number are YYJZ.
by Indridi
2.4 GHz Core 2 Duo (T8300)
Intro Date: February 26, 2008 Disc Date: October 14, 2008
Order No: MB133LL/A Model No: A1260 (EMC 2198)
Subfamily: Early 2008 Model ID: MacBookPro4,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 200 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
by oldturkey03
Indrid, start here. System shuts down almost immediately after startup:
Disconnect all external peripherals and eject any ExpressCard.1.
Make sure a known-good battery is fully inserted. Check battery charge and make sure that 2. at least two LED charge indicators light up; otherwise connect the adapter. The adapter LED should light when plugged in. If not, consult the MagSafe power adapter section for further troubleshooting.
After charging for a while, if the battery does not seem to charge, or if it is charged up but 3. quickly discharges, replace the battery. Verify with a known-good battery.
Check battery connection to logic board, and check wire attachment to connectors.4.
If just before the system shuts down, the sleep LED briefly comes on, check the three thermal 5. sensor connections to the main logic board. They should be fully seated with no damage to the wiring. If any thermal sensor is damaged, replace it.
If a known-good battery does not charge, replace the left I/O board.6.
Replace the logic board.
by oldturkey03
Any missing history - when did the problem first occur? Was the machine dropped or wet? OS update or other install?
by originalmachead
Show 2 more comments
