How can I check the disk drive?
Is there a way to check if the HDD has failed? I get Fanfare and a flashing question mark.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Turned out to be a loose HDD connection.
Add a comment
Start up holding down the Command & R keys: http://support.apple.com/en-us/HT4718
Add a comment
Thank you for the input.
I started a tear-down again and found the HDD connection popped loose when I re-installed the WiFi antenna. There's a tale of caution!
Steen Rancher
Add a comment
Add your answer
Steen Rancher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 126
