After replacing the WiFi antenna, I can't turn on WiFi
Replaced the digitizer and severed the WiFi antenna. Replaced the WiFi antenna (removed logic board), and WiFi was working but very weak (needed to be right next to the router). Opened up the iPad and reseated the antenna (this time by popping out the little WiFi IC daughter card). Partially reassembled the iPad, but now WiFi is greyed out. Did I screw something up? What process should I follow to determine what part needs to be replaced next? iPad boots fine - just WiFi and bluetooth are not working... Thank you.
