This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
146 Questions View all
Charging for few minutes but won't turn on.
Hi.
My brother accidentaly got wet my DSL. It won't turn on. The LED turns green for 2-3 seconds, but DS doesn't do anything. When I set it to charge it's charging for 5-10 minutes and then the LED stops glowing. I've bought new battery, but it's not working.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
hi
sounds like your motherboard has blown, this can be repaired but it's pretty tricky to do this - you'd be better off buying a second hand motherboard and replacing it
note though that depending on how much water got in there, it may have also waterlogged the screens as well - if that's the case then you'd be better off buying another second hand ds - they're cheap enough on ebay these days
hope that helps
Score 1
Comments:
Thanks! Yeah, they are pretty cheap. :)
by
Add a comment
Check the F2 fuse to see if its blown
Add a comment
Add your answer
Denis Bogdan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 144
