Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3265 Questions View all
Display and touch doesn't work
Hi, i have a problem with my iphone 4 gsm. after a fall the screen went black and it broke. I replaced the display (I've tried 3-4 of them) but the problem is that you see a central oval clearer and the rest black with some lines and halos but no system image. There is something that probably should not be. help me please. thank you
Score 1
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Hi, Did you disconnect the battery and make sure the phone was powered off when you replaced the display assembly? I have seen iPhone's not boot up properly or not display anything or display a white screen if the battery was still connected and the phone's power was powered on when the display assembly was connected. Could be the power button was pressed accidentally when the display was disconnected and the battery still was connected to the motherboard. I recommend making sure the phone is powered off before opening. Then disconnect the battery connector from the motherboard when you do the screen replacement? Then disconnect and reconnect the digitizer and LCD screen connecters to the motherboard and make sure they are connected tightly and reconnect the battery and power it on. Hope this helps.
iPhone 4 (GSM/AT&T) Screen Replacement
Add a comment
Add your answer
riccardo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 42
