The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1419 Questions View all
iPhone Not Turning On, But Is Recognised In ITUNES?
My iPhone has stopped working. I cant turn it on, but is recognized in iTunes.
I have Tried Holding the Lock & Home button together to reset, to not avail.
Nothing is showing on the screen. its not vibrating either so its not the screen.
HELP!! I DON'T HAVE AND WARRANTY LEFT AND NEED THIS FIXED
THANKS IN ADVANCE FOR ANY INPUT
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
If the phone is still receiving messages/calls etc and is turned on then you need to check the lcd connection and replace if necessary
Add a comment
Most Helpful Answer
If nothing is showing on the screen, the screen may be damaged, or the LCD flex cable has come loose from the logic board. The first step I would try is to disconnect the battery for a few seconds and then reconnect it.
Score 1
Comments:
I have Disconnected the battery for about a minute. But no change. Even if the screen is damaged, the Phone would still vibrate. switching it from mute to normal would also make it vibrate
by
Add a comment
After checking all the flex cables to be fully seated and make good connection I would try to put on a new screen assembly and see if that fix the problem.
Comments:
Ok, i have just tried a NEW Screen but still nothing. I just had a thought about the Power/Lock Button maybe not working?
Is there anyway to bypass pressing it, like you can with the home button? (But surely when i charge the phone, it should turn on, and i would see it charging, so maybe not. Any other ideas?
by
FIXED: With a new Screen fitted, i then held the POWER button & Shorted the HOME BUTTON TERMINALS Internally. This reset the phone. It not turns on and works fine. Just need to get a replacement Home Button Ribbon. Job Done.
THANKS FOR ALL YOUR HELP!!
by
Add a comment
i think it is in recovery mode..
Add a comment
Add your answer
Graham will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 24
Past 30 Days: 84
All Time: 1,220
