The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
4025 Questions View all
Why does screen go dark when tilting too far back or forward?
I have a MacBook (Black) model about 3 1/2 years old.
The problem that recently started is related to the angle of the screen when open. The brightness and the light adjustments all work normaly, except when pushed back past 100 (est) degrees as well as forward past 70 (est.) degrees the screen goes to the darkest setting just barley showing its content. The screen operates with its norman brightness when in upright position within those 2 angles.
Genius bar people said it maybe caused by pinched wire, but couldn't further explain unless they took apart to examine. ($200. ++).
I would like to fix this my self as I have been 'inside' before. I would like to find instructions for this if possible.
Bruce
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Inverter cable has to be replaced.
MacBook Core Duo Inverter Replacement
Score 1
Add a comment
Most likely is a pinched display data cable. MacBook Display Data Cable
Tell us exactly which MacBook you have and we direct you to the correct part and instructions for replacement.
Add a comment
Add your answer
Bruce will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,103
