Repair information and guides for the fifth generation of iPhone. Model: A1387
2192 Questions View all
Need iPhone 4s volume buttons to spring in and out?
Have iphone 4s with nonfunctioning volume +/- buttons. Could feel that mechanically they were not actuating. Followed iPhone 4S Volume Buttons Replacement
At step 9, as volume buttons removed, 2 tiny concave metal domes (1-2 mm diameter maybe) fell out. Instructions did not mention these.
I replaced with new volume buttons, and put the tiny domes on the brass circles seen in https://d3nevzfk7ii3be.cloudfront.net/ig...
Reassembled phone, and volume - worked but not volume +.
Can you point me to instructions? My problem is not the buttons but the button assembly.
I found
https://www.youtube.com/watch?v=Kl3JsKKs...
and the solution of "glue on a piece of rubber" seems interesting, but neither of my brass circles has a piece of rubber now, and the video does not mention the metal domes.
All cordial advice welcome. Thanks!
Score 1
Add a comment
Chosen Solution
The volume up, volume down (and the power button) are made the same way:
1- On top: 1 square or rectangular rubbery cover; color orange or clear (in the photo you showed us, they are orange)...
2- ...with a small rubber button in the middle. This rubber button can be clear, part of the rubbery cover; or black, glued on the surface (on that same photo, the button is black). This is the pressure point that clicks on the 2 domes underneath it, causing contact.
3- Underneath the square or rectangular small rubber: a springy square or rectangular metal dome;
4- On bottom: a second metal dome, but if you look closer, you will see that this one is covered with something white inside (underneath) the dome.
If you are missing any of the 4 components, your pressure button will not make contact and will not work.
And this is why your volume up/down buttons were not working. Not because the metallic buttons are defective: the metallic part hardly "breakdown."
But because the buttons of the Headphones Jack and Volume Control cable running underneath the metallic buttons broke down. How do they break down? Due to repeated mechanical action, either the small rubber button (2) is smashed, or detaches; or the whole rubbery cover (1) detaches, letting the springs underneath it (3 and 4) loose (which is what happened in your case, and why the 2 small metallic domes fell out).
This is the guide that you should be following to repair the volume up/down functionality.
You could of course restore the buttons themselves instead of the whole cable, but you will need to scavenge the missing rubbery cover and the 2 metallic domes for each button from somewhere (I usually use other cables with matching buttons). And more often then once, the assembly does not last as long as a new cable. So my advice is to install a new cable but watch out around the headphones jack as it may easily tear the flat cable.
Score 1
1 Comment:
Thanks for the prompt and careful answer. I ordered the cable, and I feel confident that that will resolve this problem.
by
Add a comment
This is a frequent problem with the 4S volume buttons on early phones. There is a fix of adding a shim between the volume buttons and the volume flex cable. I am still trying to find a source for apple part number 723-0072. The local Apple Care store said they do not repair volume buttons and cannot obtain piece parts. E-bay doesn't have it either. I may have to McGyver something and will post an update.
More info in the blog post below.
http://markshangout.com/blog/2013/8/22/i...
Cheers!
HeroHans
Add a comment
Add your answer
stressfields will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 978
