Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3231 Questions View all
What chip is this one?
Can anyone define what is the chip as in the picture.
After water damage this part is really hot and consumes battery even when phone is off. The phone is in working condition.
Thank you
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
What you are pointing at is L9, An inductor for LED flashlight. U17, which is right next to L9 under the shield, is somehow shorted, which causes L9 to constantly run on full power.
Score 2
Comments:
Thank You for the answer.
Any suggestion how to overcome such issue? What is U17 used for? if I remove the L9 what do I lose?
Regards
by
I removed the L9 and now is not overheating anymore nor the battery is draining.
The only drawback is the Flash is not working
by
U17 is the flash light power converter.
by
Add a comment
Add your answer
Avdulla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 161
